flent install archpi
FIXED- Subscribe to RSS Feed
- flent install archpi
12-08-2017 7:16 PM
Anybody help with installing flent on arch-raspberry pi.
Works ok in Mint-Gui and console mode but I can't figure out how to install it on the pi with an arch build.
It's not in the rasbpian repo or the arch repo, so a little stuck!
I have..
ls
BUGS README.rst flent-mime.xml man setup.py
MANIFEST.in batchfile.example flent.desktop misc unittests
Makefile doc flent.egg-info packaging
PKG-INFO flent flentrc.example setup.cfg
@alarmpi flent-1.0.1]$ cd flent
@alarmpi flent]$ ls
__init__.py combiners.py metadata.py settings.py util.py
__main__.py error_ellipse.py plotters.py testenv.py
aggregators.py formatters.py resultset.py tests
batch.py gui.py runners.py transformers.py
build_info.py loggers.py scripts ui
Do I need to install the dependacies first ?
I've also tried the PKGBUILD as well
Or am I just going about this the wrong way ?
Fixed! Go to the fix.
12-08-2017 10:02 PM
Can't you just use pip or pip3 install flent?
Re: flent install archpi
12-08-2017 11:30 PM
sudo pacman -S python-pip resolving dependencies... looking for conflicting packages... Packages (7) python-3.6.2-1 python-appdirs-1.4.3-1 python-packaging-16.8-2 python-pyparsing-2.2.0-1 python-setuptools-1:36.2.7-1 python-six-1.10.0-3 python-pip-9.0.1-2 Total Download Size: 18.31 MiB Total Installed Size: 111.39 MiB :: Proceed with installation? [Y/n] y :: Retrieving packages... python-3.6.2-1-armv6h 16.6 MiB 3.86M/s 00:04 [######################] 100% python-pyparsing-2.... 92.3 KiB 1845K/s 00:00 [######################] 100% python-six-1.10.0-3-any 17.9 KiB 0.00B/s 00:00 [######################] 100% python-packaging-16... 28.7 KiB 718K/s 00:00 [######################] 100% python-appdirs-1.4.... 13.6 KiB 1356K/s 00:00 [######################] 100% python-setuptools-1... 270.5 KiB 1229K/s 00:00 [######################] 100% python-pip-9.0.1-2-any 1367.5 KiB 1140K/s 00:01 [######################] 100% (7/7) checking keys in keyring [######################] 100% (7/7) checking package integrity [######################] 100% (7/7) loading package files [######################] 100% (7/7) checking for file conflicts [######################] 100% (7/7) checking available disk space [######################] 100% :: Processing package changes... (1/7) installing python Optional dependencies for python python-setuptools [pending] python-pip [pending] sqlite [installed] mpdecimal: for decimal xz: for lzma [installed] tk: for tkinter (2/7) installing python-pyparsing (3/7) installing python-six (4/7) installing python-packaging (5/7) installing python-appdirs (6/7) installing python-setuptools (7/7) installing python-pip :: Running post-transaction hooks... (1/1) Arming ConditionNeedsUpdate... [barclay@alarmpi ~]$ pip install flent Collecting flent Downloading flent-1.0.1-py2.py3-none-any.whl (246kB) 100% |################################| 256kB 212kB/s Installing collected packages: flent Exception: Traceback (most recent call last): File "/usr/lib/python3.6/site-packages/pip/basecommand.py", line 215, in main status = self.run(options, args) File "/usr/lib/python3.6/site-packages/pip/commands/install.py", line 342, in run prefix=options.prefix_path, File "/usr/lib/python3.6/site-packages/pip/req/req_set.py", line 784, in install **kwargs File "/usr/lib/python3.6/site-packages/pip/req/req_install.py", line 851, in install self.move_wheel_files(self.source_dir, root=root, prefix=prefix) File "/usr/lib/python3.6/site-packages/pip/req/req_install.py", line 1064, in move_wheel_files isolated=self.isolated, File "/usr/lib/python3.6/site-packages/pip/wheel.py", line 345, in move_wheel_files clobber(source, lib_dir, True) File "/usr/lib/python3.6/site-packages/pip/wheel.py", line 316, in clobber ensure_dir(destdir) File "/usr/lib/python3.6/site-packages/pip/utils/__init__.py", line 83, in ensure_dir os.makedirs(path) File "/usr/lib/python3.6/os.py", line 220, in makedirs mkdir(name, mode) PermissionError: [Errno 13] Permission denied: '/usr/lib/python3.6/site-packages/flent-1.0.1.dist-info'
12-08-2017 11:43 PM
baaaaaaaaaaaaaaaaaah tired eyes
sudo pip install flent
[sudo] password for barclay:
Collecting flent
100% |################################| 256kB 210kB/s
Successfully installed flent-1.0.1
12-08-2017 11:55 PM
sudo pip install matplotlib Collecting matplotlib Downloading matplotlib-2.0.2.tar.gz (53.9MB) 100% |################################| 53.9MB 1.2kB/s Complete output from command python setup.py egg_info: IMPORTANT WARNING: pkg-config is not installed. matplotlib may not be able to find some of its dependencies ============================================================================ Edit setup.cfg to change the build options BUILDING MATPLOTLIB matplotlib: yes [2.0.2] python: yes [3.6.2 (default, Jul 22 2017, 20:34:44) [GCC 7.1.1 20170516]] platform: yes [linux] REQUIRED DEPENDENCIES AND EXTENSIONS numpy: yes [not found. pip may install it below.] six: yes [using six version 1.10.0] dateutil: yes [dateutil was not found. It is required for date axis support. pip/easy_install may attempt to install it after matplotlib.] functools32: yes [Not required] subprocess32: yes [Not required] pytz: yes [pytz was not found. pip will attempt to install it after matplotlib.] cycler: yes [cycler was not found. pip will attempt to install it after matplotlib.] tornado: yes [tornado was not found. It is required for the WebAgg backend. pip/easy_install may attempt to install it after matplotlib.] pyparsing: yes [using pyparsing version 2.2.0] libagg: yes [pkg-config information for 'libagg' could not be found. Using local copy.] freetype: no [The C/C++ header for freetype2 (ft2build.h) could not be found. You may need to install the development package.] png: no [pkg-config information for 'libpng' could not be found.] qhull: yes [pkg-config information for 'qhull' could not be found. Using local copy.] OPTIONAL SUBPACKAGES sample_data: yes [installing] toolkits: yes [installing] tests: no [skipping due to configuration] toolkits_tests: no [skipping due to configuration] OPTIONAL BACKEND EXTENSIONS macosx: no [Mac OS-X only] qt5agg: no [PyQt5 not found] qt4agg: no [PySide not found; PyQt4 not found] gtk3agg: no [Requires pygobject to be installed.] gtk3cairo: no [Requires cairocffi or pycairo to be installed.] gtkagg: no [Requires pygtk] tkagg: yes [installing; run-time loading from Python Tcl / Tk] wxagg: no [requires wxPython] gtk: no [Requires pygtk] agg: yes [installing] cairo: no [cairocffi or pycairo not found] windowing: no [Microsoft Windows only] OPTIONAL LATEX DEPENDENCIES dvipng: no ghostscript: no latex: no pdftops: no OPTIONAL PACKAGE DATA dlls: no [skipping due to configuration] ============================================================================ * The following required packages can not be built: * freetype, png ---------------------------------------- Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-build-dw84lyz6/matplotlib/
off to bed....
13-08-2017 8:41 AM
@30FTTC06 - You're unable to build some requirements so start by installing the build tools:
sudo pacman -S --needed base-devel
And as you have Python 3.6 installed if it's not there already install pip3 and then re-try a matplotlib using it:
sudo pip3 install matplotlib
pip3 is the preferred installer when using python 3
13-08-2017 2:01 PM - edited 13-08-2017 2:05 PM
Cheers @Anonymous got there in the end..
sudo pacman -S python-matplotlib
sudo pacman -S python-matplotlib resolving dependencies... looking for conflicting packages... Packages (8) blas-3.7.1-1 cblas-3.7.1-1 lapack-3.7.1-1 python-cycler-0.10.0-2 python-dateutil-2.6.1-1 python-numpy-1.13.1-2 python-pytz-2017.2-1 python-matplotlib-2.0.0-1 Total Download Size: 10.74 MiB Total Installed Size: 47.74 MiB :: Proceed with installation? [Y/n] y :: Retrieving packages... blas-3.7.1-1-armv6h 70.8 KiB 1771K/s 00:00 [################################] 100% lapack-3.7.1-1-armv6h 1483.8 KiB 3.53M/s 00:00 [################################] 100% cblas-3.7.1-1-armv6h 25.3 KiB 2.47M/s 00:00 [################################] 100% python-numpy-1.13.1-2-armv6h 2.2 MiB 3.30M/s 00:01 [################################] 100% python-pytz-2017.2-1-any 157.6 KiB 3.85M/s 00:00 [################################] 100% python-dateutil-2.6.1-1-any 219.8 KiB 3.58M/s 00:00 [################################] 100% python-cycler-0.10.0-2-any 11.0 KiB 0.00B/s 00:00 [################################] 100% python-matplotlib-2.0.0-1-a... 6.6 MiB 3.80M/s 00:02 [################################] 100% (8/8) checking keys in keyring [################################] 100% (8/8) checking package integrity [################################] 100% (8/8) loading package files [################################] 100% (8/8) checking for file conflicts [################################] 100% (8/8) checking available disk space [################################] 100% :: Processing package changes... (1/8) installing python-pytz [################################] 100% (2/8) installing blas [################################] 100% (3/8) installing lapack [################################] 100% (4/8) installing cblas [################################] 100% (5/8) installing python-numpy [################################] 100% Optional dependencies for python-numpy python-nose: testsuite (6/8) installing python-dateutil [################################] 100% (7/8) installing python-cycler [################################] 100% (8/8) installing python-matplotlib [################################] 100% Optional dependencies for python-matplotlib python-gobject: for GTK3Agg/GTK3Cairo backend python-cairocffi: for GTK3Agg/GTK3Cairo backend python-pyqt4: for Qt4Agg backend tk: used by the TkAgg backend ghostscript: usetex dependencies texlive-bin: usetex dependencies python-tornado: for webagg backend python-pillow: for reading/saving .jpg/bmp/tiff files :: Running post-transaction hooks... (1/1) Arming ConditionNeedsUpdate...
~]$ flent tcp_download -p totals -l 60 -H netperf.bufferbloat.net -t text-to-be-included-in-plot -o bob.png Started Flent 1.0.1 using Python 3.6.2. Starting tcp_download test. Expected run time: 70 seconds. Data file written to ./tcp_download-2017-08-08T192010.844588.text_to_be_included_in_plot.flent.gz. Initialised matplotlib v2.0.0 on numpy v1.13.1.
13-08-2017 4:43 PM - edited 13-08-2017 5:27 PM
I quite like this flent...
Edit: RPI gives a rubbish graph hmmm.
Fast pc...
