firefox update
rongtw
Fixes: 12
firefox update
15 REPLIES 15
Legend
Fixes: 255
Re: firefox update
Nice try - but Mozilla never release updates like that - as I'm sure you.re aware @rongtw
Wonder if it's wannacry trying a new attack vector - the source site looks v.suspicious - and a FF update delivered in that format - never in a million years.
Fixes: 1,600
Re: firefox update
Thanks for posting this as a heads up. Thumbs_Up
It does appear to be a bit dodgy.
Re: firefox update
Appear! dodgy it's screaming fake.
Fixes: 1,600
Re: firefox update
I never make any guarantees. Wink
rongtw
Fixes: 12
Re: firefox update
@Anonymous as soon as i saw page address ,,,, OOOPS no way
Re: firefox update
@rongtw - You got that for a reason so please check your PC over just to be on the safe side, it appears repeatedly then you may have been hijacked.
shutter
Fixes: 65
Re: firefox update
@rongtw  did you report it to FIREFOX HQ  ? ? ? ?
rongtw
Fixes: 12
Re: firefox update
@shutter yes on the Firefox support pages there were several posts , i added mine too Thumbs_Up
St3
Aspiring Champion
Fixes: 5
Re: firefox update
Is firefox better than chrome ? Ive never tried it before
Re: firefox update
It is all down to choice I guess, I can't see past it (or Thunderbird for Mail) myself, so best option would be to download, install and run it for a while and see what you think. It's all very well others commenting but this is for your use not theirs.
shutter
Fixes: 65
Re: firefox update
@St3
From what I have seen on this forum,..... Chrome does a lot of unsolicited covert spying and reporting back to google... which, may be true,... or not... and you .... may... be able to adjust some settings ...
as @Anonymous  says... choice is yours, as you will be the one to use it ... or not... it may well have some features that you would like to use that are not availabel on Firefox.
Mav
Fixes: 515
Re: firefox update
I use a mixture of three browsers depending on a sites content/needs and for keeping things separate.
I mainly use FF for general browsing, Chrome for content that contains Flash and IE for banking.
Forum Moderator and Customer
VileReynard
Fixes: 20
Re: firefox update
IE for banking? Crazy2
Mav
Fixes: 515
Re: firefox update
It's as secure as any other browser.
