firefox update
- Re: firefox update
firefox update
23-05-2017 6:48 PM
odd i just got this ,, I dint open it just to warn others
Re: firefox update
23-05-2017 7:14 PM - edited 23-05-2017 7:17 PM
Nice try - but Mozilla never release updates like that - as I'm sure you.re aware @rongtw
Wonder if it's wannacry trying a new attack vector - the source site looks v.suspicious - and a FF update delivered in that format - never in a million years.
Re: firefox update
23-05-2017 7:17 PM
Re: firefox update
23-05-2017 7:22 PM
Appear! dodgy it's screaming fake.
Re: firefox update
23-05-2017 7:27 PM
Re: firefox update
23-05-2017 8:03 PM
@Anonymous as soon as i saw page address ,,,, OOOPS no way
Re: firefox update
23-05-2017 9:07 PM
@rongtw - You got that for a reason so please check your PC over just to be on the safe side, it appears repeatedly then you may have been hijacked.
Re: firefox update
24-05-2017 1:12 PM
@rongtw did you report it to FIREFOX HQ ? ? ? ?
Re: firefox update
24-05-2017 1:24 PM
@shutter yes on the Firefox support pages there were several posts , i added mine too
Re: firefox update
26-05-2017 9:39 AM
Is firefox better than chrome ? Ive never tried it before
Re: firefox update
26-05-2017 9:57 AM
It is all down to choice I guess, I can't see past it (or Thunderbird for Mail) myself, so best option would be to download, install and run it for a while and see what you think. It's all very well others commenting but this is for your use not theirs.
Re: firefox update
26-05-2017 12:30 PM
@St3
From what I have seen on this forum,..... Chrome does a lot of unsolicited covert spying and reporting back to google... which, may be true,... or not... and you .... may... be able to adjust some settings ...
as @Anonymous says... choice is yours, as you will be the one to use it ... or not... it may well have some features that you would like to use that are not availabel on Firefox.
Re: firefox update
26-05-2017 4:34 PM
I use a mixture of three browsers depending on a sites content/needs and for keeping things separate.
I mainly use FF for general browsing, Chrome for content that contains Flash and IE for banking.
Forum Moderator and Customer
Re: firefox update
26-05-2017 5:12 PM
IE for banking?
Re: firefox update
26-05-2017 5:14 PM
It's as secure as any other browser.
