event viewer
- Re: event viewer
event viewer
29-09-2008 1:23 PM
DHCP Error 1002
The IP address lease 192.168.1.2 for the network card with network address (long number) has been
denied by the dhcp server 192.168.1.1 (the dhcp server sent a dhcpnack message).
This is not my IP address....is there anything for me to worry about. Am an oldie.
Thanks for reading
Re: event viewer
29-09-2008 1:30 PM
Re: event viewer
29-09-2008 3:48 PM
Re: event viewer
29-09-2008 3:57 PM
Maybe that was a router IP address it was checking.
Often get "you have a plug disconnected", but have only this comp. Computer works OK just this message in event viewer.
Until yesterday only had plus net router and windows firewall, now have Comodo and lots of anti malware spyware etc.
All compatable and one off using . No Tea timer or the like. Only Spyware blaster.
Thanks for your interest
Re: event viewer
29-09-2008 5:22 PM
Re: event viewer
29-09-2008 6:23 PM
When the lease is denied the stack should request a new one, so this is nothing to worry about but is always recorded in the EV
FYI, the one reported by shields UP is one from Plusnet's IP pool which has been allocated to your router on a fixed or dynamic basis (dynamic ones change every couple of days)
Re: event viewer
29-09-2008 6:42 PM
Many thanks to all much appreciated.Nothing to worry about until the next worry
Vaguely thought I was being hacked.
Re: event viewer
29-09-2008 6:57 PM
Re: event viewer
29-09-2008 7:00 PM
Re: event viewer
29-09-2008 9:36 PM
Re: event viewer
29-09-2008 10:05 PM
