error message on startup error -5009 : 0x800703ee while running the setup
kenny
I`m getting an error message on start up. It started a couple of days ago (been trying to sort a problem with a USB Flip Mino posted question in hardware group)
The error message is :
Error code -5009
any idea how to get rid of it. I`m using WinXP Pro with all updates on
pierre_pierre
Re: error message on startup error -5009 : 0x800703ee while running the setup
Download startupcpl free from
http://www.mlin.net/StartupCPL.shtml
It will show whats is running on startup there will be something related to you Mino trying to install untick it to stop it. Its part of your failed software install
Njal
http://forums.techarena.in/windows-update/261828.htm
"The 0x800703EE error normally indicates that one or more files have either
been altered, have been lost, or are corrupted so that they cannot be
opened or cannot be read once open.
This could mean file corruption on your system, or that your AV software
is preventing reading of the file, or that some other 3rd party
application is interfering.
As a start I'd recommend you close all applications, do a full "Scan for
errors" on the drive you are using, and of course a full anti-virus and
malware scan.
If the problem persists, try to determine what file is causing the
problem. You may be able to get clues for this in the WindowsUpdate.LOG
file located in your Windows folder ....."
See also further down the thread, someone got this error with a corrupt cdm.dll file.
Try a restore installation?
Regards,
Neil
kenny
Well this is what the error is saying when I open it up in full:
Error Code: -5009 : 0x800703ee
Error Information:
>Ctor\IScriptWrapper.cpp (27)
>Ctor\ObjectWrapper.cpp (163)
>Ctor\ObjectWrapper.cpp (384)
>Kernel\Component.cpp (875)
>Ctor\ObjectWrapper.cpp (34)
>Ctor\DriverWrapper.cpp (31)
>Kernel\Component.cpp (864)
>Kernel\CABFile.cpp (263)
>SetupDLL\SetupDLL.cpp (1611)
pAPP:
PVENDOR:
PGUID:
$7.1.100.1248
@Windows XP Service Pack 3 (2600) BT_OTHER 101.114
Did you find anything in the startup that shows a failed install? You can try deleting all the files in your temp dir as often this is the problem but you need to find what i tis thats running at startup and stop it
