enex file extension
- enex file extension
enex file extension
06-09-2010 10:55 AM
Hi
Can enyone help with opening these files. I've had a couple sent to me at work (Office 2003) They seem to be some varient of xml. Would I be able to open them in Office 2007 at home?
2 REPLIES 2
Re: enex file extension
06-09-2010 11:10 AM
ENEX appears to be a Evernote exported XML file
Try using this to open it http://www.evernote.com/about/download/
06-09-2010 12:46 PM
Thanks Old Jim
The site is blocked at work, so I'll give it a go from home.
