email problems
- Re: email problems
email problems
23-10-2008 6:01 PM
Is it just me, or have there been email problems over the last couple of days?
Both yesterday and today, I've had problems sending emails (although they're coming in ok)
The error message reads "unable to connect to the server ... error number 0c800ccc0e"
4 REPLIES 4
Re: email problems
23-10-2008 6:05 PM
That error is associated with your outgoing SMTP server settings (thats why you can still receive). Could you please let us know what email client you are using and what settings you have for the outgoing mail server
Jeff
Jeff
Re: email problems
23-10-2008 6:46 PM
I had that yesterday, some message about smtp and the mail appeared to fail. I'm not sure if it sent so i forwarded a copy of the mail and that went ok.
I am using Outlook Express on Windows XP. I'm on Option 3 and was sending using a domain name which is not hosted by Plusnet.
Re: email problems
24-10-2008 12:38 AM
No issues I'm aware of. I'd commonly expect to see an error like that when antivirus/security software is having a moment.
Re: email problems
24-10-2008 10:33 PM
Thanks Guys.
It has been working fine, and I haven't changed anything recently. I restarted my router and it all went ok. Could that have caused a problem?
I find that I have to restart the Belkin router every few days, or I start to lose sync with my desktop.
