email from addressbook friend goes to junk in local folders
- Re: email from addressbook friend goes to junk in ...
15-01-2008 7:40 AM
I use Thunderbird as my email client. In PN i use mailboxes and have filters set so that messages from folk who are not in the addressbook are directed to the Junk folder. I can extract the few genuine items and add them to the address book.
Yesterday, however, an email from an addressbook friend went to the Junk folder, because I was not the first named in the list of folk he was contacting.
How can I ensure that such emails go straight to the appropriate maibox?
3 REPLIES 3
Re: email from addressbook friend goes to junk in local folders
15-01-2008 9:09 AM
In the Thunderbird rules I suspect to have the "To or cc" option selected with "is" selected from the middle box - changingh that to "contains" might be all that is needed.
However, you've probably found that another problem with this is if you are sent an email as a BCC it does not pick up your name.
If on the rule, instead of selecting To or cc you add another header using the Customise option (at the bottom of the list) called Envelope-to and put your name in there it should also pick up the BCC.
15-01-2008 9:30 AM
@jelv In fact the sender had not used the Cc or Bcc option, but recipients separated by semicolons. Does that alter ypur reply?
15-01-2008 9:36 AM
No, both methods should work.
Contains will find a match wherever it is in the list.
Delivered to is added by the Plusnet email server and is only ever the one address which identifies the email address that copy of the email is being err... delivered to.
