email delivery failure
- Re: email delivery failure
07-04-2016 12:25 PM - edited 07-04-2016 12:29 PM
I thought it was impossible for an email not to be delivered and there not to be an error message. However I seem to have found a situation where the SMTP server relay.plus.net does exactly that. I can send an email via said server from my Entourage client and it appears to send perfectly normally yet does not get delivered and no error message comes back to me. I have of course done all the checks on spam filters etc. . Has anyone else seen this behaviour?
07-04-2016 12:29 PM
Have you got any details of the issue? What's happening, any error messages?
07-04-2016 12:31 PM
see my edited post.
07-04-2016 1:45 PM
- Are you sending from a Plusnet email address?
- Where is the recipient/to address hosted? With Plusnet, or somewhere else?
- Does this only affect emails sent to or from a certain address?
Based on the limited information you've provided, the issue is more likely to be at the recipient's side. If the receiving server accepts the email and silently discards it, then no message would be sent back to relay.plus.net to suggest anything other than a successful delivery.
07-04-2016 2:56 PM
OK, I have tried some combinations:
If I send from a yahoo address to a plusnet address using relay.plus.net it delivers OK
If I send from a yahoo address to another yahoo address using relay.plus.net it fails with no error message.
07-04-2016 3:03 PM
If you message me with the two Yahoo! addresses in your final example, then I'll check to see if I can spot anything untoward.
We used to suppress failed delivery notices to non-Plusnet addresses sending though our relays but I'm not sure if that's still the case.
If you forward me the above details, then I can definitely tell you whether or not the Yahoo! servers are accepting messages.
on 07-04-2016 4:45 PM - last edited on 07-04-2016 8:52 PM by dvorak
Sending address was removed and recipient address was removed
dvorak removed email addresses as it's a public forum
07-04-2016 5:11 PM
Yahoo's servers are definitely accepting emails from/to those addresses:
~$ telnet relay.plus.net 25 Trying 212.159.8.107... Connected to relay.plus.net. Escape character is '^]'. e220 avasout02 smtp relay.plus.net ehlo relay 250-avasout02 hello [84.93.219.165], pleased to meet you 250-HELP 250-AUTH LOGIN PLAIN 250-SIZE 104857600 250-PIPELINING 250-8BITMIME 250 OK mail from:<mssxxxxxxxxx@yahoo.co.uk> 250 <mssxxxxxxxxx@yahoo.co.uk> sender ok rcpt to:<braxxx@yahoo.co.uk> 250 <braxxx@yahoo.co.uk> recipient ok data 354 enter mail, end with "." on a line by itself subject: Test message from Plusnet Support This is a test message, please ignore! . 250 fU8j1s0093aiV8c01U9HtU mail accepted for delivery quit 221 avasout02 smtp closing connection
PS: You might want to edit your post to obscure those email addresses.
08-04-2016 1:51 PM
I didn't doubt that the Yahoo servers were accepting the addresses because I have sent directly to them. The question remains why is the plusnet server neither passing on emails sent to it for these addresses nor returning an error message?
08-04-2016 3:59 PM
The SMTP transaction shows me connecting to our relay server and sending the message from there using the addresses you provided. If our servers weren't accepting the message, were silently dropping the message, or Yahoo were rejecting the message, then I'd have encountered problems.
The question remains why is the plusnet server neither passing on emails sent to it for these addresses...
The evidence I've provided shows that they are.
I wonder if the individual I sent the test message to received the email?
