email clients
petlew
email clients
I've forgotten how long I've been using Thunderbird email, certainly before we moved here and that was approaching eighteen years ago. But I noted in my favourite computer magazine today that although Thunderbird has had a very recent update, Mozilla support for it is, to quote, "on borrowed time".
I'm wondering if anybody on this forum would like to recommend a replacement for Thunderbird. And also why any others are not recommended.
I do realise that this is a bit like asking "how long is a piece of string", but educated comments would be appreciated.
Prior to Thunderbird I was happily using MS Outlook Express, but decided (and I can't remember why) to cease using any MS products other than operating systems and Office.
18 REPLIES 18
ReedRichards
Seasoned Pro
Fixes: 25
Re: email clients
It has become very hard to find decent email client software.  These days you are supposed to want to access your emails across multiple devices and ISPs are rapidly losing interest in providing their clients with email accounts.  So you are left with Microsoft and Google.  They want you to access your emails via their web sites so they can feed you advertisements.
petlew
Re: email clients
Thanks Reed Richards. I have considered going back to MS and using the Win 10 "Mail", but this has a flaw for me as it only allows a max of three accounts, and I currently have five, nor does it allow multiple contact .Cc/.Bcc, both essential for me, they're unlimited in Thunderbird. In fact Mail has not scored very highly in reviews at all.
I've also considered MS Outlook. I have this on my Office 2007 disc (but never installed it), but that version of Office is no longer going to be supported by MS very soon if it hasn't already stopped. So that may be going as well in favour of Libre Office.
I've also thought about dropping email from the PC altogether and relying on that embedded in my iPad/iPhone. Whilst it does allow multiple accounts, its not so good at some other elements.
In fact the only one that entirely meets my requirements is...Thunderbird.
shutter
Fixes: 65
Re: email clients
@petlew
googling...  "alternative to Thunderbird"... gives this page
https://www.google.co.uk/search?q=alternative+to+thunderbird&oq=alternative+to+thunderb&gs_l=psy-ab....
Take your pick.... as a certain TV show host used to say  ! ! !..... Wink
Oldjim
Resting Legend
Fixes: 63
Re: email clients
When I looked at moving my better half's emails from XP and Outlook Express to Win 10 Thunderbird seemed to be the only one which did what was needed so the real question is - what will be the effect of it no longer being supported given that it works and does what she wants
petlew
Re: email clients
Yes Old Jim, you're quite right. Its the potential security holes that might appear post support that are most worrying I suppose. I like to think Kaspersky as a safety net should be Ok. Kaspersky certainly has email protection, but is that enough...
7up
Fixes: 17
Re: email clients
If it helps I use Outlook 2003! I've not had any problems and its so old i doubt hackers will bother targetting it.
VileReynard
Fixes: 20
Re: email clients
Why the dash to change from a stable product?
Email was defined & implemented many years ago - Thunderbird isn't going anywhere soon.
petlew
Re: email clients
I'm not rushing, just reacting to an article in this weeks Computer Active issue 513 p53. (I get mine before the shops as I subscribe to it, so its not out just yet). Its not a long article but I wouldn't think it a good idea to quote it verbatim.
I'm not stopping using Thunderbird any time soon just yet, just like to be ready if its required.
@7up this makes interesting reading: http://home.bt.com/tech-gadgets/computing/software/is-it-safe-to-use-an-old-version-of-microsoft-off...
Don't I recall, and I admit straight away I may be failing in memory here, but didn't you once say in forums that you decline to use any AV or security at all. If it wasn't you I apologise unreservedly.
VileReynard
Fixes: 20
Re: email clients
You recall correctly - but I don't use Microsoft products and I'm careful not to open unrecognised URL's in emails.
7up
Fixes: 17
Re: email clients
I'm not sure if the lack of security products was aimed at me or vile.. but if it was me..
I use AV and security stuff but I don't install windows updates. They tend to cause more hassle than they solve IMO so i don't bother with them.
Strangely (and i'm sure my day will come) it's never caught up with me yet unlike millions of others round the planet who get had by all the latest attacks..
ReedRichards
Seasoned Pro
Fixes: 25
Re: email clients
A long long time ago when you received an email with a file attachment then the email client program would helpfully open the attachment for you.  If the attachment was a program it would be executed.  This offered huge scope to infect a computer with a virus by sending an email because just the act of reading the email would execute the virus program.  Email client programs no longer automatically open attachments but the trauma from this time has left behind an exaggerated perception of the 'danger' of emails.   Reading an email is a perfectly safe activity and you do not need security software with "email protection".  If you try to open a virus file then your security software should protect you, whether or not that file arrived in an email.  Some security software will block links that lead to 'bad' web sites but, I think, only if the site is on a pre-existing database.
petlew
Re: email clients
That hasn't prevented very high profile attacks on Win 98 systems, and that pre-dates Office 2003 by some way.
Moderator's note by Mike (Mav): Quote fixed.
7up
Fixes: 17
Re: email clients
You're talking about windows 98!
Office 2003 came around 5 years odd later.
ReedRichards
Seasoned Pro
Fixes: 25
Re: email clients
Not such a high profile that I have heard of them.  Can you cite a reference?  Where Windows 98 still exists it is most likely to be embedded in some system.
