early life photos for a fiftieth
- early life photos for a fiftieth
- « Previous
- 1
- 2
- Next »
Re: early life photos for a fiftieth
02-08-2018 9:42 PM
@Luzern ok .. did a test print on the 6x4 photo paper... with three sheets in the tray.... first go, it reported no paper, so gave the paper tray a quick "in and out" and then no problem printing. Used the print control on my laptop, not the one on the printer. set the paper for 6x4 and photo glossy,... set same on the printer,... also use "other" for both, as previously mentioned.
Did a diagnostics, and test print... see pics
05-08-2018 7:08 PM
@Luzern Am assuming that, as there was no reply, or further info, that you have given up on 6x4 printing !
Probably not worth taking it in to "some guy" who would charge about five times the price of a new printer, just to give you a price for fixing it ! ! ..
To save you that bother....... you may find the answer on this site...
https://www.fixyourownprinter.com/
Haven`t used it for years... ! ( since my HP Deskjet 840c ! )... but worth a look.....
05-08-2018 7:48 PM - edited 05-08-2018 7:56 PM
It has been suggested that part of the problem may be the print head, that could have been disturbed, when the printer was dropped. I'm waiting an opportunity to deal with, old clothes and help, if needed, for this crinkly.
BTW after toiling through the link, the MG6800 series is not there.
05-08-2018 9:09 PM
Oh ! OK... well that save me looking if I ever needed it ! .
- « Previous
- 1
- 2
- Next »
