driving me nuts
- driving me nuts
driving me nuts
16-09-2007 11:43 AM
i wonder if you could help me out
when i run certain programmes i keep on getting this popping up on screen
for example when running idsuite programme
IDSuite.exe - Application errror
The instruction at "0x0067706a" referenced memory at "0x0067706a".
The memory could not be "read"
Click ok to terminate the programme
Any ideas what it is and how to rectify this as it is stopping progammes in mid stream and as i put it driving me nuts
thanks in advance
Re: driving me nuts
16-09-2007 11:47 AM
Update via Windows Update (or another updating service) and you should be fixed.
Re: driving me nuts
16-09-2007 2:52 PM
It is also a system monitoring program that records your activity which may have been installed either intentionally or via a virus/malware infection.
Re: driving me nuts
17-09-2007 1:20 AM
It may say cant run do you want to do it on next boot if so say yes
Re: driving me nuts
17-09-2007 3:25 AM
running win 2000(yes its old but it has been stable...tried the rest)
all updated as of yesterday
ran spybot and adaware
also chkdsk
could it be a ram problem namely a failure in a stick
Re: driving me nuts
17-09-2007 9:33 AM
Quote from: cookie141 all updated as of yesterday
Thats like bolting the door after the horse etc.... were spybot and adaware fully updated before you ran them as they need to be and have you also run a full updated virus scan
Quote from: cookie141 could it be a ram problem namely a failure in a stick
Yes it could well be amongst other things so give memtest a run and see if it finds any errors
What was the outcome of running chkdsk c: /f... did it fully complete with no errors in good time or was it very slow but completed or did it not complete at all
Re: driving me nuts
17-09-2007 11:00 AM
Adaware and spybot and ran them again
the problem has now been rectified
Thanks for all the input guys
Cookie
Re: driving me nuts
17-09-2007 12:33 PM
Re: driving me nuts
17-09-2007 3:08 PM
Re: driving me nuts
17-09-2007 3:17 PM
There's an article in the Microsoft KB about this problem, which was why I suggested the update.
Just curious
Re: driving me nuts
17-09-2007 7:34 PM
i installed this on the 3rd September 2007
Security Update for Internet Explorer 6 Service Pack 1
same as
hope this answers your question
