drive capacity
plantsman
drive capacity
Hi, can anyone advise me on how to make my O/S XP pro recognise the full capacity or a Hitachi HDD. This will be a new drive and I will be loading it with the above O/S. I have service pack 2 on a separate disk but  of course this can't be added until after the bios has already seen the drive.
This situation occured on a different computer and it only recognised a small amount of the capacity but I just accepted it and did not enquire further as to why that  was., This time I don't want to lose drive space.
Peter
My site
http://www.raffia.plus.com/
19 REPLIES 19
Strat
Fixes: 565
Re: drive capacity
What's the size of the drive?
HPsauce
Re: drive capacity
It shouldn't be a problem.
Unless the drive has jumpers that allow you to restrict it's physical capacity - check on its label.
Or it's a very old motherboard  Undecided
plantsman
Re: drive capacity
It's a new motherboard - Gigabyte GA-MA770-DS3 and the drive is Hitachi 320GB.
VileReynard
Fixes: 20
Re: drive capacity
Split it into two partitions - one for your chosen OS and one for your data.
pierre_pierre
Re: drive capacity
I have a low end laptop XP SP3  with a 500G USB hard drive - not partioned - no problem
Strat
Fixes: 565
Re: drive capacity
...but, with respect sir, it's usually a good idea to keep OS and data on separate partitions.
pierre_pierre
Re: drive capacity
so - the original question was, I cant read all my disc only 320Gb
Strat
Fixes: 565
Re: drive capacity
Not quite Pierre but at least we are back on topic Wink
pierre_pierre
Re: drive capacity
Quote from: plantsman
how do you mean not quiet
samuria
Re: drive capacity
You need to slipstream SP2 or 3 into the cd or it wont see it you can get software for your drive that may get around the problem
see
http://www.tomshardware.com/forum/139796-32-windows-disk-size-limit
to slipstream the sp3 see
http://www.howtohaven.com/system/slipstream-xp-service-pack-3.shtml
This assumes you mb can see greater than 137 meg which being new it should does the bios correctly identify the drive?
VileReynard
Fixes: 20
Re: drive capacity
137GB is equivalent to 28bits (if used to address 512 byte sectors)
A modern OS would use 48 bit addressing - which is ample for any conceivable disk.
I don't understand why 32 bit addressing was ever used though.
artificer
Re: drive capacity
an alternative to slipstreaming a service pack is to install xp, then install sp2 if you have it on cd.  you can then access disk management and expand the partition to fill the rest of the disk, or make a new partition.
plantsman
Re: drive capacity
Sorry for the delay gentlemen - many thanks, problem solved
HPsauce
Re: drive capacity
problem solved
How?
