dlinkg604t
- dlinkg604t
dlinkg604t
09-08-2007 5:54 PM
hi.
i have the above router, with a block of static ips. these are needed for several pcs to game together in same game.
im now trying to put a pc in system with a private ip. the problem is that dhc
p, shows only the static public ip range and will not accept a 192 number.
no matter what i set the card on this pc to, it does not see the router.
f/w and nat on for portforwarding.dhcp off. nat off for the connection as a whole.
ideas appreciated
ideas appreciated
2 REPLIES 2
Re: dlinkg604t
10-08-2007 12:02 PM
Doing a quick google search suggests it can support multiple IPs but its not simple to setup.
http://www.expansys.com/ft.aspx?k=16242 may help
Try googling for 'g604t multiple IP' or 'g604t ip block' and see what else there is.
Edit to add: Do you have a block of 4 or 8 IPs. Remember a 4 IP block only gives you 2 usable IPs (the 2nd & 3rd in the block with the 2nd assigned to th router). With 8 you have 6 usable, the 2nd allocated to the router.
Re: dlinkg604t
10-08-2007 12:48 PM
thz.
block of 8. i understand 5 are usable.
these are setup or poss not correctly.
but see no way to add another pc on a 192/10 number. will
try ur suggestions. thz
