dg834g v4 DOS blocking XBL port 3074
- Re: dg834g v4 DOS blocking XBL port 3074
21-05-2009 1:22 AM
had trouble tonight i was hosting a race pro match. my friend and few other joined but i couldnt see them and after min or so they said they got kicked.
i also couldnt message my friend or invite it kept say cannot process or somthing on the dashboard error code.
i checked upnp and dmz was o.k and it was, but on the router logs i got this lot so i had to turn dos and port scan protection off and every thing was fine. theres alot more DOS on 3074 on the logs but that gives the picture
dont worry my friends ip is'nt on there as he's with sky and 1 is for micosoft and the other for tiscali
firmware 5.01.14
firmware 5.01.14
Quote Wed, 2009-05-20 21:05:23 - UDP Packet - Source:88.107.242.36,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:24 - UDP Packet - Source:65.55.42.130,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:24 - UDP Packet - Source:88.107.242.36,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:28 - UDP Packet - Source:65.55.42.130,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:28 - UDP Packet - Source:88.107.242.36,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:38 - UDP Packet - Source:65.55.42.130,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:38 - UDP Packet - Source:88.107.242.36,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:42 - UDP Packet - Source:65.55.42.130,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:42 - UDP Packet - Source:88.107.242.36,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:43 - UDP Packet - Source:88.107.242.36,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:51 - UDP Packet - Source:65.55.42.130,3074 Destination:10.0.0.2,3074 - [DOS]
Wed, 2009-05-20 21:05:51 - UDP Packet - Source:88.107.242.36,3074 Destination:10.0.0.2,3074 - [DOS]
1 REPLY 1
23-05-2009 5:56 AM
downgraded back to V5.01.09 and the issue is no longer there
plus upnp on .14 was more pants than .09 i had 2 identical port maps for spotify if i closed it down and opened it again and also to clear maps on .09 i have to turn upnp off and on sometimes but .14 this trick wouldnt work and only way to clear them was to reboot router
