destop
tynygongl
destop
I have a new computer - Acer - and when I open anything from desktop it only opens half size (then I have to maximize) Acer told me to do a factory restore; it took 2 hrs and hasn't solved the problem. Any ideas? I am no expert!
Fixes: 62
Re: destop
Do you get the same thing if you double click on the exe file rather than the short cut
Fixes: 24
Re: destop
Explain to Acer that the factory reset did not fix the problem so they must replace it under warranty.
tynygongl
Re: destop
To Oldjim,
sorry, but I don't know what you mean by exe file
Fixes: 86
Re: destop
It's an executable file, a file with .exe after it's name such as firefox.exe
Customer and Forum Moderator.
Re: destop
If you right button click an item (program shortcut) on the desktop, then select 'properties' from the pop-up menu there should be a box where you can select to run in 'Normal window', 'Minimized' or 'Maximized' (Microsoft's spelling, not mine), does selecting 'Maximized' have the desired effect?
Call me 'w23'
Fixes: 24
Re: destop
If you have this problem and it survived a factory reset then hundreds of other people who bought the same model of computer built at about the same time will have the same problem.  Acer should be becoming aware of this and it's up to Acer to find a fix for you.  Take it back to the shop if necessary.
tynygongl
Re: destop
1. I still don't know what you mean by an exe file, and I don't understand how this might help. ( I am a complete novice to how computers work)
2. I've tried properties on desktop item but I can't find anything saying minimize, maximize etc.
Fixes: 62
Re: destop
Lets go back to basics
When you say click on anything on the desktop do you mean in the task bar or something you have saved to the desktop such as a picture or do you mean the start menu accessed from the globe on the lower left
tynygongl
Re: destop
To Oldjim,
First, thanks for your patience! I have created a number of shortcuts to my desktop eg. Google as homepage, Plusnet etc. It is these which only open half size. I have tried opening from the Windows menu and this seems to be OK. Hope this is clear.
Fixes: 17
Re: destop
If the Google "Search Page" is opening "half size", you may have it set as default.  (without realising it) ....
At the top right corner check on the little boxes... look at the middle box, next to the X..... if it is showing as a single square box, this is showing the page as a "small size".  If it is showing as two overlapping boxes it is showing it as "full size"...
If it is showing as a single box, click on it, and the page will (should) revert to Full Size,... now close the page by clicking on the X...  next time you click on the short cut for Google..... it should open as a full size page...
(Hopefully !  Cheesy )
Fixes: 62
Re: destop
Those shortcuts all open Internet Explorer and as such the chances are that it is the Internet Explorer settings which are the problem or are there other shortcuts which aren't internet related which have the same effect
Is this a correct assumption
tynygongl
Re: destop
Oldjim,
The answer is Yes.
Fixes: 62
Re: destop
If you open Internet Explorer by itself is it full screen or windowed - by that I mean half size
tynygongl
Re: destop
Oldjim,
If I open IE itself, it's full-size.
To Shutter: I've checked your suggestion but it didn't apply, thanks though
