curl
curl
C:\Users\user2>curl https://www.amazon.co.uk
Warning: Binary output can mess up your terminal. Use "--output -" to tell curl to output it to your terminal anyway,
Warning: or consider "--output <FILE>" to save to a file.
After using --output (with resultant unreadable output), the binary stuff displayed in a command line window rang my bell (after a delay of about 5-6 seconds). A ding-dong (which my mail client plays when new mail arrives). The mail client wasn't active at the time.
Trying curl with other websites over https doesn't result in the same.
Does anyone have any (technical) insight? 'Googling' amazon and curl just brings up hair curling utensils marketed on amazon.
10 REPLIES 10
Fixes: 480
Re: curl
Moderator's note:
Thread moved from Everything Else to Tech Help
TheRoadCrew
Fixes: 13
Re: curl
From the curl man page:
DESCRIPTION
curl is a tool for transferring data from or to a server using URLs. It supports these protocols: DICT, FILE, FTP, FTPS, GOPHER, GOPHERS, HTTP, HTTPS, IMAP, IMAPS, LDAP, LDAPS, MQTT, POP3, POP3S, RTMP,
RTMPS, RTSP, SCP, SFTP, SMB, SMBS, SMTP, SMTPS, TELNET, TFTP, WS and WSS.
 You would need to specify which data you want to transfer
Something like
curl -O https://mirror.server.net/linuxmint/iso/debian/lmde-6-cinnamon-64bit.iso
would download (transfer) that iso image.
Alternatively, I may be misunderstanding what you are asking.
TheRoadCrew
Fixes: 13
Re: curl
Actually, running
$ curl https://www.amazon.co.uk > amazon.txt
saves the output for me. Forum software won't let me attach the txt file 'cos it contains html.
Re: curl
OK
running
Screenshot of the first page of the resultant amazon.txt
TheRoadCrew
Fixes: 13
Re: curl
I don't see any binary at all:
Amazon_txt.jpgOdd that only Amazon behaves this way for you; don't know if why do i get binary output using curl? is relevant in this case.
Re: curl
It was the '--compressed' option that was the solution. Thanks. Smiley
Although I am unsure why I need to specify that when you don't. One answer often leads to more questions.
TheRoadCrew
Fixes: 13
Re: curl
If you are using curl shipped by Microsoft perhaps it has something to do with the curl alias (if it still exists).
Fixes: 251
Re: curl
Could this be the difference between running in Poweshell vs a CMD prompt?
Re: curl
Dunno, but I'll give it a test later. (This will only be under Win10. Whether there's a difference under Win11 I may never find out).
I'll go back and give Roadcrew a 'fix'. In the dim and distant past I've come across gflate(?) in HTTP and that had been relegated to the back of my brain into the 'use it or lose it' category.
Re: curl
It appears that a momentary warning(?) flashes up (in yellow, before disappearing) in Powershell (both as a 'normal' user and as an admin), then it appears that powershell automagically tries the --compressed option.
