cookies
firefly2
cookies
hope that this doesn't sound too stupid [ i feel it ]
where do I find my cookies if have them and if blocked,  how do I allow a few....
thanks  Embarrassed
Fixes: 62
Re: cookies
Which browser are you using
pierre_pierre
Re: cookies
[hide] well she is a Woman, do they know? /hide
firefly2
Re: cookies
hi  Oldjim >> int explorer.
@ pierre,,,, you are very naughty.. they are not in the oven, that's for sure. Roll eyes
Fixes: 62
Re: cookies
assuming you are using IE7 go to Tools, Internet Options, General then click on Settings under Browsing History and you will get something like this picture
Click on View Files and you will see all the cookies
I am not sure how to block or unblock sites but if, under Internet Options, you click on Privacy do you see something like this (second picture)
pierre_pierre
Re: cookies
IE6 is virtually the same Smiley
firefly2
Re: cookies
thankyou both..
did what you said Oldjim and it told me that I had over the limit of 1024... [of allsorts]
so have reduced them as suggested.
thanks again. perhaps that is what may have slowed the pc down ...
expect it is stocked with loads that I could get rid of.  Smiley
pierre_pierre
Re: cookies
the recycle bin is next then, then you could look at you browsing history.
didnt really look at what jim said do, did you do a selected delete of the cookies, as some store things that you might want
Re: cookies
Wot a lot of cookies Firefly. If you download CCleaner it will ditch the lot and your computer's waistline will be all the thinner for it!
firefly2
Re: cookies
hi Poppy .. had a shock. .. it was over 2000.
a few are needed tho' as some downloads won't work without them...
still I know more than I did when I got up... thanks for interest all .. Smiley Smiley
Re: cookies
Just checked in CCleaner and in the options section you can elect to keep the cookies that you wish to retain - looks quite easy to do.
I just usually clear the lot at the end of the day.
firefly2
Re: cookies
thanks poppy will do the cclean. is it in mainenance?
@ pierre. didn't sort out the cookies so hope that what have saved will be okay. I saved 250.
thanks for all interest to all  Smiley
pierre_pierre
Re: cookies
you get oddy cookies, like the PN speedtest remembers its history in a cookie, and some logons are also in cookies, the ones to get rid of are the advert ones Cool
firefly2
Re: cookies
Oh !!!! will look later then. thanks .. only came in for a cuppa and a scone ... rest from gardening.. : Cool
pierre_pierre
Re: cookies
great minds think alike, just having my coffee, then out to sort out garden, have to check out my auto watering from last year as off for a week beginning may and got Toms in hanging baskets and spuds in barrels
