constant change of local IP.. stop!?
- constant change of local IP.. stop!?
Re: constant change of local IP.. stop!?
18-12-2017 4:49 PM
so set a static or?
18-12-2017 4:53 PM - edited 18-12-2017 4:54 PM
18-12-2017 4:54 PM
ill try again later, what are the dns required?
18-12-2017 4:57 PM
Yes @marc2, set a static IP on your Plex server (i.e. the Windows 10 PC it runs on) and set the same IP on the router. Remember to apply the rules regarding the choice of IP address you use to make your life easier. i.e. One outside of the DHCP range of the router. I think that 192.168.1.3 is outside of that range but someone, or yourself, might need to confirm that.
I've included a link below on how to set the static IP for those that might find it useful in the future.
https://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
This link also covers Windows Vista, XP and 7 to 10.
18-12-2017 4:57 PM - edited 18-12-2017 4:59 PM
18-12-2017 4:57 PM - edited 18-12-2017 5:00 PM
You don't need to change the DNS at all.
Edit:- I assume you're referring to the static network connection setting then see @MJN's post above.
18-12-2017 4:58 PM
i know how to set a pc ip not sure how to do the same in router
18-12-2017 4:58 PM
18-12-2017 5:01 PM
You don't need to set anything in the router as regards the staticness of an IP, just enter the same IP e.g. 192.168.1.3 into the applicable field when forwarding the port.
18-12-2017 5:02 PM
18-12-2017 5:03 PM
my router forwarding is choose an app and then chose a port range etc. as shown. just put in the internal ip?
18-12-2017 5:05 PM
18-12-2017 5:11 PM - edited 18-12-2017 5:12 PM
@marc2 The TG582 doesn't let you port forward to an IP address reference but rather the 'Device' dropdown will list all the devices it has seen by machine name or pseudo-MAC name. Find your server by either of these (running ipconfig /all at the command line will reveal its MAC address).
18-12-2017 5:12 PM
yes i can already choose my pc name and thats when it works
i choose plex then edit and choose my pc name, then works for a while
18-12-2017 5:14 PM
