connecting Samsung mobile phone for emails
daveregester
I have followed all the steps as far as I can see and I cannot get it to work.The guide seems to be about iPhones but not the Samsung. Has anyone else had any trouble please?
Re: connecting Samsung mobile phone for emails
Welcome to the forums.
I use the Samsung Galaxy S2. This is how I set up email on my phone:
Go into applications and select email. Touch the left hand button at the bottom of the screen and on the pop-up menu touch 'more'. Another menu pops up and select Account settings.
You should then be able to enter your Plusnet account details and server settings to complete the operation.
On the server settings I've used:  incoming server settings POP3 server mail.plus.net using port 110 and outgoing server setting relay.plus.net using port 25.
Hope this helps.
daveregester
Thank you artmo for your expeditious and extremely successful reply.  This is the first time I have used a forum and I am still struggling with how to do things on it.
No problem. Glad it worked Smiley
