computer dead
- computer dead
computer dead
20-10-2007 8:11 AM
AMD Athlon 1.40
512 MB Ram Windows XP Prof
Re: computer dead
20-10-2007 10:05 AM
However a few thoughts if you would like to investigate further.
It could is a duff power supply.
Can you borrow another one and test
It could also be the motherboard or the connections to it
However it would be worth doing a few diagnostics first. Do you know which motherboard you have and is there a manual with it.
What we should be looking for is diagnostic lights on the motherboard and whether they light up when the computer fails to start.
Re: computer dead
20-10-2007 2:21 PM
Re: computer dead
20-10-2007 4:55 PM
Re: computer dead
20-10-2007 6:11 PM
Re: computer dead
21-10-2007 12:12 AM
Is there a light inside the case on the motherboard when its on? a lot have it and its normally on even when the power is off(but plugged in). if you can see the light it 89% likely its not the power supply
Re: computer dead
21-10-2007 1:02 PM
Re: computer dead
22-10-2007 1:03 PM
Re: computer dead
22-10-2007 7:09 PM
Re: computer dead
23-10-2007 1:16 PM
Re: computer dead
23-10-2007 6:43 PM
I had something like this a long time ago, which I don't remember getting to the bottom of.
Removing the power lead or switching off at the plug socket for 5 or ten seconds allowed the PC to boot normally.
Hope this helps.
Re: computer dead
28-10-2007 2:21 PM
Re: computer dead
29-10-2007 12:27 PM
