computer case spares
Fixes: 9
I Have a coolmaster elite 330 case & the plastic switch that powers up the computer has broken. Its more of a plastic button that covers the switch rather than the switch itself. Does anyone know where I might obtain a spare switch ? I have looked on the coolmaster website but the contact addresses are abroad and a request for somewhere in the UK who might supply spares has met with no response.
Fixes: 62
Re: computer case spares
Have you tried here as I think it isn't coolmaster but coolermaster http://www.coolermaster.nl/shop/index.php
Fixes: 9
Oldjim,
Thanks for your response, I have had a look on the site but can't see what I am looking for, however I have e-mailed them.
I guess if they can't help me nobody can.
Fixes: 62
I would also try contacting this company http://www.kustompcs.co.uk
They are a Coolermaster stockists and are probably the most helpful company in the business
When we had the pc shop we could never get spares for cases it was down to glue it  swap the power and reset buttons or tape the switch on the case and use that its safe to do so. Failing that its a new case.
JohnGalloway
same happened with my Coolermaster Elite case - it's a rubbish design for a switch,  Sad
however, i emailed shop@coolermaster.nl
and they kindly sent a replacement, fairly promptly.  Grin
think they're based in in the Netherlands.
wixi
