computer case spares
- Re: computer case spares
10-02-2009 3:37 PM
I Have a coolmaster elite 330 case & the plastic switch that powers up the computer has broken. Its more of a plastic button that covers the switch rather than the switch itself. Does anyone know where I might obtain a spare switch ? I have looked on the coolmaster website but the contact addresses are abroad and a request for somewhere in the UK who might supply spares has met with no response.
We are born into history and history is born into us.
5 REPLIES 5
10-02-2009 3:44 PM
Have you tried here as I think it isn't coolmaster but coolermaster http://www.coolermaster.nl/shop/index.php
10-02-2009 4:48 PM
Oldjim,
Thanks for your response, I have had a look on the site but can't see what I am looking for, however I have e-mailed them.
I guess if they can't help me nobody can.
10-02-2009 4:53 PM
I would also try contacting this company http://www.kustompcs.co.uk
They are a Coolermaster stockists and are probably the most helpful company in the business
10-02-2009 11:40 PM
When we had the pc shop we could never get spares for cases it was down to glue it swap the power and reset buttons or tape the switch on the case and use that its safe to do so. Failing that its a new case.
03-11-2009 2:32 PM
same happened with my Coolermaster Elite case - it's a rubbish design for a switch,
however, i emailed shop@coolermaster.nl
and they kindly sent a replacement, fairly promptly.
think they're based in in the Netherlands.
wixi
wixi
