clonezilla
- clonezilla
clonezilla
03-04-2013 11:24 PM
Is the app easy enough to use. I did have a magazine cover disk with paragon drive copy, but its expired.
Would welcome any advice
Re: clonezilla
04-04-2013 7:51 AM
I've never used it for HDD to HDD, I've cloned a HDD into an image then restored the image to another HDD or Virual machine.
Works very well but make sure you read all menus carefully .......
The only issues I've ever had is if there are file system errors or unclean unmounted drives but a scandisk before doing a clone will make sure you don't have any issues.
Re: clonezilla
04-04-2013 9:46 AM
You can clone it as is, expand the partitions, copy individual partitions etc, very detailed.
Re: clonezilla
04-04-2013 9:51 AM
Vigor 130 modem, pfSense 2.4.5-p1 router, 5 WAPs, Devolo dLAN 500, Gigaset N300A-IP VoIP DECT
Re: clonezilla
04-04-2013 10:24 AM
Re: clonezilla
04-04-2013 6:04 PM
Re: clonezilla
04-04-2013 8:57 PM
I own a licence for the full version now, but prior to that I used the free version to migrate a Windows XP system to a newer hard drive (by backing up to a USB drive, and then restoring that image to the new disk).
You may be able to enlarge the 40GB partition to 120GB during the restore (I can't remember whether this is available in the free version), but if not, you should be able to use the built-in disk utilities in Windows to enlarge the partition afterwards.
Re: clonezilla
05-04-2013 11:47 AM
Re: clonezilla
05-04-2013 8:51 PM
I appreciate your help, and yes, all I need is at the min, a 1 time migration. I will have a look at the 2 other options, and have a think
Cheers
Re: clonezilla
07-04-2013 11:04 AM
