change background colour of a PDF
- change background colour of a PDF
21-01-2014 7:44 AM
Can anyone advise the best way to change the background colour of a pdf and make it permanent
as in the attached sample from pink to white
1 REPLY 1
Re: change background colour of a PDF
21-01-2014 3:57 PM
Assuming you don't want to buy acrobat pro, you can open the file in Libre Office, you can play with it...
The pink background is an image, which incorporates part of Figure 4.1 and a couple of other bits where the text is deformed.
If you edit that image you can change the pink for whatever you like, you can then re print the document as a PDF.
