cell format in Open Office
FIXED- Subscribe to RSS Feed
- cell format in Open Office
02-01-2020 3:25 PM
Using open office, spreadsheet... I want to display time in a column of cells... as 14:00 but the default is showing 14:00:00
I have tried to change it,....but cannot get it to work using the toolbar or the "format" .. please can someone point me to the right thing to click on !
cheers
Fixed! Go to the fix.
02-01-2020 4:06 PM
@shutter just tried with LibreOffice, select the cell range,select Format cells,Time and top of list is the HH:MM format
Re: cell format in Open Office
02-01-2020 5:26 PM
@MisterW Ah. Yes !.... thanks for that.... what a pity it is a "hidden" thing.... whereas, most others are "drop down" menu`s...
Much apprreciated.
Thanks again.
