carn't dowload McAfee sofware
twilightflyer
I inadvertantly removed McAfee from my account and now I have tried to reinstall it I find that the McAfee Vitual Tech reports that the product update is required, can anyone help please.
I am running IE7, and the sofware was running OK before I had removed it.
2 REPLIES 2
ReedRichards
Seasoned Pro
Fixes: 25
Re: carn't dowload McAfee sofware
Think yourself lucky and take the opportunity to ditch McAfee and install the free Microsoft Security Essentials instead.  If you want to be sure you are completely free of MAfee use the removal tool here http://service.mcafee.com/FAQDocument.aspx?id=TS101331
D4v3
Hi twilightflyer,
I have now resolved this issue with your Plusnet Protect service and updated your ticket. I hope this helps.
