can i put a referal name in after account set up
- can i put a referal name in after account set up
29-04-2013 10:11 PM
Hi just ready to sign my daughter up for unlimited and phone through the cashback sites and noticed they will not give cashback if you put a referal name in so is there anyway to put a name in later after she is set up
Or is it one or the other
Robert
Robert
7 REPLIES 7
Re: can i put a referal name in after account set up
29-04-2013 10:37 PM
I believe that if your daughter raises a ticket advising that you are the referral and vice versa it should go through - I haven't bothered digging into past posts as it wasn't very recent but i believe that this was confirmed.
Best thing is to wait for staff to confirm (or otherwise) tomorrow
29-04-2013 10:55 PM
Thanks will wait and see what they say
Robert
Robert
29-04-2013 11:43 PM
having been affected by a similar issue recently, I'll concur with Old Jim, that both you and your referral should raise a ticket about the issue.
30-04-2013 11:33 AM
any chance of an answer for this as i would like to get an order in today
Robert
Robert
30-04-2013 5:03 PM
You certainly do need a staff member answer since I was under the impression that going through a cash back site precluded referral payments completely - i.e. the latter couldn't even be retrospectively added.
David
01-05-2013 4:06 PM
I believe the option to add a referrer isn't there on signup if you do go through somewhere like quidco or topcashback, but as far as I'm aware there's nothing to stop us adding them afterwards
@crobertbailey if you raise a ticket and you get your referrer/referee to do the same (and reference each other's usernames on the respective tickets) we'll get the referral added for you.
01-05-2013 8:02 PM
Another thanks to you Matt
