can i order a new router
roberkwild
hi all,
just wondering can i order another router from plusnet just as a spare, or can i only order one if my one has troubles, i thought you can, all you do is pay P&P
4 REPLIES 4
Chris
Legend
Fixes: 169
Re: can i order a new router
I'm afraid not, the routers are not free for us to purchase so we would only send one out as a replacement, new signup, or recontract.
roberkwild
thank you,
just because my gf's dad is with plusnet and he has the old thomson one, so he couldnt order a new one from yourselves?
PeterLoftus
Fixes: 5
Have a look at other threads on here. Most seem to settle on getting a ex BT Hub 5 on eBay. Cheaper and good functionality. PN's offer is good for just P&P but not full price  Smiley
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
shermans
I have looked on eBay and they range in price from £5 to £36.  But I am a little confused.
The PlusNet Thompson router has very limited range in an old cottage with very thick walls.  Would a BT Home Hub 5 have more range, I wonder ?  I do note that I can often see neighbours' BT routers listed with a stronger WiFi signal than my own !
Also what is the difference between a Home Hub 5 A and 5 B, if any, in terms of performance ?
And finally, some of them say "fibre router".  Do I need to have fibre to use them ?
Thanks.  Any advice appreciated.
mav:quote
