can a cheap bluetooth headset be used with skype on a windows pc / laptop ???
- Re: can a cheap bluetooth headset be used with sky...
26-01-2014 12:18 AM
and if so
What are the Plus & Minus points
Re: can a cheap bluetooth headset be used with skype on a windows pc / laptop ???
26-01-2014 5:28 AM
26-01-2014 2:16 PM
That job came to an end and I've been using it via bluetooth ever since for ocassional use as a microphone / earpiece for music / skype.
Plus points:
- You have no wire
- Easy to use (though software might be a bit of an issue - I think I'm using the toshiba blue tooth driver for the usb bluetooth adapter which is a Tesco Technika adapter lol)
- Freedom to move about
- Sound is reasonably clear for speech
Bad points:
- Sound for music isn't great but it is usable
- More EM radiation and most of it is going through your head / brain
- Relies on batteries that eventually go flat (that said, mine lasts for ages but typically it'll shut off in the middle of a great track ::))
- Sound quality worsens the further away you go from the computer though this is usually several meters away
- You only get mono sound not stereo
So yes, it can be done but it isn't ideal.
26-01-2014 2:53 PM
My bad I should of been a bit more clearer as I wasn't looking to purchase any as I already have 3 similar to the 1 7up mentioned as I picked them up as part of a deal (dont ask unless you want the long distance to China story )
like 7up I use 1 whilst on my travels as it seems to be an extra limb these days
@7up
thank you for the detailed information
Now I can unseal 1 of the 2 unused B/T H/S and set it up for SWMBO for skype as she is always gassing to her family down South and she wont be tied up (Hmm dont get me started on that 1)
Can a womans head / brain get any more fried ??
26-01-2014 3:16 PM
I also use mine for the phone when on the phone to my brother and cousin - both of which always end up being long conversations lol.
Not sure about your software as the default windows software didn't want to do it for me but if you PM me I will sort you out the toshiba bluetooth stack if I can find it on my HDD.
26-01-2014 3:36 PM
I will see how it goes later, as I am playing catchup due to loss of connection and family life taking over (and have the peace & quiet) for a short while
Plus SWMBO has taken her Laptop over the stepdaughters as she is helping her with her Uni studies (dont ask!!!)
If it helps it will be mainly used with a Vista laptop however she doesn't know it yet but will be upgraded to Win 8.1 with all the bloat removed or replaced, when I find the time
26-01-2014 5:20 PM
On its default fully installed drivers I can go into the Audio settings and click Test and I get the test sound through the H/S, the option for the H/S to set as default is greyed out, I have tried disabling the spkrs and the spkrs are still working but no sound from WMP to H/S.
Did you have the same or similar issues 7up ?
Send you that PM
Edit:
Avast auto update just spoke via the H/S if that's any help
26-01-2014 8:59 PM
I got your PM, I'm uploading the file now. It's a self extracting archive but I've put it in a .rar file as I don't know if PN's webserver allows .exe files or not. Alternatively you can search for Toshiba blue tooth stack.
Anyway this is the device I use:
From Tesco about £6 a few years ago. Works perfectly with the Toshiba drivers, not sure about other devices though.
26-01-2014 9:46 PM
It sorted itself out after a reboot due to other software updates
So unsure if closing & re-opening WMP would of worked as I closed it prior to the updates and was going to look at it later however you post changed my mind
A stupid noob mistake that I should never of overlooked
P.S
I got your PM
and all d/loaded fine and ready for action if required many thanks
Still have to wait to get my mitts on SWMBO's laptop to test with Skype
Will keep you informed
P.S
Did you get that test PM you was waiting for
26-01-2014 11:22 PM
26-01-2014 11:29 PM
27-01-2014 1:18 AM
I swear my PM inbox has been so busy this week I feel like a plusnet celebrity - 7 today alone lol
27-01-2014 2:04 AM
BTW
You are running out of images as I keep seeing the same 3 - 5 x per day since your changes
At 1st I thought I had too many bevies
27-01-2014 2:27 AM
There are tons of avatars on the server and they're set to random but I think it's often picking the same ones for some reason - seems to change daily. Today I've seen the stickman from the matrix doing a lot of fighting yet the other day I kept seeing several of the others quite often. Seems to vary wildly for some reason lol but i will keep an eye on it!
TV ads.. lol don't think so me and PN have history together although I must 'fess that Bob P has been very helpful and kind recently.
You say you've downloaded the toshiba thing? - I can delete it then yes?
27-01-2014 2:14 PM
