caller ring delay on plustalk.....
markus
HI , i have a yamamoto USB deskphone, using plustalk PAYG, set up with the correct driver for x-lite. My plusnet bandwidth test shows about 1.8 to 1.95 Mbps pretty regularly
the problem is that when somebody calls me, i will answer it, the call stops ringing my end but carries on ringing for 4 to 6 rings at the callers end..... anyone know what can be done to resolve this?
cheers
mark
1 REPLY
Fixes: 82
Re: caller ring delay on plustalk.....
I posted a response to this in the (wrong) forum here.
