buying 3 large items discounts?
amcclean
I'm looking at potentially ordering 3 items of IT equipment but would like to know if any company does decent discounts when you spend a decent amount with them.
Sadly doubt any would do a buy tow get third free but would appreciate some type of discount.
cheers,
podman
2 REPLIES 2
shutter
Fixes: 64
Re: buying 3 large items discounts?
If you don`t ask...... you don`t get...
So... whichever supplier you choose, always have the second choice available, in your head.. or on paper,... then you have the bargaining power with your chosen one... i.e.... well, if you don`t / won`t give me a discount of ( say 10%) then I shall go to xxxxxxxx supplier, who has indicated they may be able to do something....
Always worth a try...  depends on how good you are at blagging and bluffing, to get it for the price you would like to pay...
Good luck
FreddieFlint
EVERYONE does discounts .. had hundreds of pounds knocked off for various bits n bobs just recently, show 'em cash and they'll do a deal. Never hurts to ask Smiley
