bt sports/sky box
deborahjane
bt sports/sky box
Hello ,I have the old type sky box,not activated,can I use this for bt sports or do I need a new box.thks Undecided
2 REPLIES 2
orbrey
Re: bt sports/sky box
I believe the box would work, but you'd need an active viewing card with an active Sky subscription in order to take the BT sport service. Hope that helps explain?
AndyH
Actually, I don't think you need an active Sky subscription - just an active viewing card (which PlusNet can supply) to get BT Sport.
