broadband stops working when phone is use
- Re: broadband stops working when phone is use
28-01-2014 8:02 PM
Does anyone else have this problem? When using phone unable to use broadband. Anyone any ideas? Thanks
1 REPLY 1
28-01-2014 8:10 PM
Easiest thing to check first is the microfilters you're using. Maybe swap them around or check everything that's connected to the phone line has one. If you're luck it may resolve things for you but if not please reply back here again.
That's RPM to you!!
