blue screen of death 0x000007b.
aldabbagh
I just a Dell Optiplex 760 from work, I Recently had a Dell Optiplex 380 ( Gave that to my son) The Dell 380 was running my Windows 2008 R2 (I know it's weird) anyways. I put the hard drive into the new Dell pc. It keeps on restarting, I get a blue screen of death 0x00007b. Also I tried deleting the old hard drive controller from the other pc and then tried to delete the hard drive driver as well.
What I can't do, try booting into safe mode, didn't work
Tried last Known Good Configuration, didn't work
Also the both PCs are Small Form Factor
Also I went to the bios, It finds the drive but it does not boot into windows. Sad
5 REPLIES 5
picbits
Re: blue screen of death 0x000007b.
Generally you can't just swap hard drives between different machines and expect the operating system to run - you'll often find it will freeze and/or BSOD.
Normally you'll need to wipe the drive and/or do a fresh install over the existing data - sometimes you can just move the existing windows folder out of the way and do a new install while keeping the data on your drive.
aldabbagh
I don't want reinstall my Domain Controller. >.> It has all my settings for my Network, such as Group Policies, Disk Quota settings and so on.
CX
Maybe one of the systems was set to AHCI mode for the SATA controller, and the other for Legacy IDE or RAID.
aldabbagh
I Just Checked the settings, its on the defualt settings
picbits
See if you can take a photo of the BSOD - often it will tell you in what module it has caused the fault and you can Google it and work back from there.
