bebo problems
kirkkirkp
bebo problems
hi all , my daughters cannot see pics. that they have put onto bebo,but they can see other peoples pics. is there any advice or software that will help open up jpegs gif + bitmaps etc.
thx
kirky
1 REPLY
VileReynard
Seasoned Pro
Fixes: 9
Re: bebo problems
Can you be a bit more specific?
There are loads of applications that can display image files (including your browser).
I believe Windows needs the extension (.png, .jpg, .bmp etc) to be present in the file name.
