automatic connection
- Re: automatic connection
21-01-2008 1:53 PM
21-01-2008 2:09 PM
Connect automatically to what? What kind of equipment are you using, i.e. if it is connecting autonatically to broadband, do you use a router or a modem?
21-01-2008 2:32 PM
21-01-2008 2:35 PM
Hope that helps,
21-01-2008 3:15 PM
21-01-2008 5:05 PM
Hope that helps,
21-01-2008 5:10 PM
Go into IE, and go to Tools->Options->Connections
You should be presented with three options:
"Always dial a connection"
"Dial whenever a network connection is present"
"Never dial a connection"
Make sure that the last option is selected (Never dial a connection).
Be advised this means that you will have to manually connect to the internet (which is what I believe you want?) by going into Start->Network Connections->(your connection name) and clicking "Connect"
B.
22-01-2008 8:52 AM
22-01-2008 9:32 AM
Go to Control Panel>Network Connections
In the Network Connections box drop down the Advanced menu.
Go to dial-up preferences and look under auto-dial.
Untick all the boxes and tick "disable autodial"
22-01-2008 11:20 AM
