another security tip
thisoldman
So you have deleted your hist temp cookies etc etc........so you think
try this and dont faint        start>run>cmd>ipconfig/flushdns
mentalist3d
Re: another security tip
I was first shown that by a techie at work as I was having trouble connecting to the internet, I only thought it was removing my asigned IP address so when I try to reconnect I get assigned a new IP address, nice to know it was clearing the clutter as well Smiley
thisoldman
txs for your reply mentalist. if you go to cc cleaner on line help forums you can read about more tips . Cheesy
Fixes: 24
What's supposed to happen then?  What happens if you then use ipconfig /displaydns?
matt_2k34
hardly seems a security tip, all that command does is flush the cached DNS entries (and forces them to be looked up again)
the only time you'd normally use this is if your having an issue getting to some websites/services
or am i missing the point?
