android phone - any app to adjust system screen and power settings?
7up
Fixes: 17
Hi gang
I think the subject sums it up really... anyone know of an app that can do it?
7up
1 REPLY 1
HairyMcbiker
All Star
Fixes: 21
Re: android phone - any app to adjust system screen and power settings?
What do you want to control exactly?
The screen settings are pretty complete, you can adjust the on time, brightness etc all from the settings app.
The power settings are more difficult, do you want more usage or what? Try This to manage running apps.
If you have root access then try Greenify
