alternative OS
- Re: alternative OS
alternative OS
07-05-2008 10:15 AM
I was wondering if theres a way to run it from an external hard drive and having the choice
Is it possible?
Has anyone made the experience?
Re: alternative OS
07-05-2008 10:21 AM
Ex-Broadband Service Manager
Re: alternative OS
07-05-2008 10:23 AM
Phil
Re: alternative OS
07-05-2008 12:14 PM
it needs to be borne in mind that there is a learning curve. it takes the average migrant six months to become truly comfortable with linux, to the extent that they no longer boot windows.
dual-boot with windows is recommended as this gives the user a 'safety blanket' for those tasks the user has yet to learn in linux.
the best approach is to visit several linux forums, pclinuxos.com, ubuntu, suse, mandriva, and others, read what the members are saying, see what issues crop up and look at lots of screenshots to see which of the many distributions grabs your fancy.
when you're ready to take the plunge, look for the downloadable .iso of the distribution of your choice and burn it as an 'image' to cd/dvd. rewritable media are good for this as you can overwrite them.
google will help in your search.
Re: alternative OS
07-05-2008 8:35 PM
Re: alternative OS
07-05-2008 9:18 PM
Computer shopper usually have some form of linux on their cover DVDs
Re: alternative OS
10-05-2008 10:47 PM
Quote from: penfold and I would 3rd it!!!... Used SUSE 10.2 and ubuntu, and ubuntu appears more user friendly to the novice.
I agree. If you have a laptop computer, Suse is an especially good choice. But Ubuntu is a really good all-rounder with masses of online documentation available via the Ubuntu support forums.
Juliasdream - unlike Windows, which has just one desktop environment with lots of different decorations, Linux offers dozens of different desktops. Make sure that you try more than one. At minimum Gnome and KDE. You can install more than one and switch between them each time you log-in to your computer
Re: alternative OS
11-05-2008 2:23 AM
SuSE has the least faff arounds for me as a desktop user after having tried the likes of:
Debian, Gentoo, RedHat, CentOS, Ubuntu, FreeBSD, NetBSD and all sorts of Micro Distros for USB Pens and Live CD's.
I settled on SuSE when I downloaded Version 10 after in 5 CD's (i386) after previously using 9.1 Personal on a PII Laptop which was running very well. I found SuSE a joy to use, and clicked with me naturally for using a Linux OS, it has and does everything thay I expect.
I never liked KDE myself, some like it's organisation of the Menus, but I think it's far too bloated and have stuck with Gnome and lighter Window Managers such as XFCE and FluxBox (on a NetBSD box).
Not everything has a Linux equivilant - I am thinking primarily in Games, and some utilities which are Commercial and aimed at Windows only.
but Linux doesn't do all bad in Emulation of native Windows applications, nor too bad in its own equivilants of Commercial software...
it just depends what the Windows program utilises, just copy over necessary DLL's and Fonts into your "Wine" folder,
and you can play the likes of Steam games in OpenGL mode, almost as good as it is on Windows with "wine".
At the end of the day, it depends what you want to do with your Computer, note down what you want,
check weather there is an equivilant or way of doing it on Linux and find which Distro does it for you.
Keep it a Dual Boot machine, I find it particularly useful from time to time when needing to upload native linux binaries for running the Games Servers.
Jim,
Re: alternative OS
11-05-2008 2:59 PM
But there are now other (exciting) alternatives. Current (June) edition of Custom PC describes setting up a "virtual Ubuntu Linux Machine) running under Windows. "It's seperate from the host machine so anything that goes wrong won't affect your main OS.....If you don't like it, you can just delete the virtual hard drive image". They rate tis on the bottom rung on their ladder of difficulty and they certainly make it look easy (pages 100 &101).
If you are into experiencing different distros of Linux you needn't stick with Ubuntu if you go down this route. One that you might look at is Linux Mint in its latest version (Daryna). It is derived from Ubuntu (or perhaps Debian from which Ubuntu came) but apparently include most proprietary stuff that you might need (unlike Ubuntu). It has an even easier installation method than Ubuntu for new software (I haven't tried it myself)
As the SuSE command prompt that you had to drop to when in trouble used to say "Have a lot of fun".
0
Re: alternative OS
11-05-2008 4:33 PM
During the install, I was careful to put the linux boot loader on the new disk.
I then amended the Windows boot loader to give me a choice of Windows or Linux. (A chained boot).
All this was totally unnecessary - but super-safe.
I never use Windows any more - but it still lurks in the guts of an old PC.
Re: alternative OS
11-05-2008 10:11 PM
Quote from: naps Ubuntu has what they call WUBI, which lets you install it as a program to run under Windows (I understand) if you just want to try it out.
Yeah, or alternatively setup QEMU, Download your Ubuntu ISO, create the Batch File and away you go - just it will be pretty slow on the Graphical Front, as it can't utilise the CPU to the full nor Graphics as such.
Quote from: naps As the SuSE command prompt that you had to drop to when in trouble used to say "Have a lot of fun".
It still does if you execute a new session of BASH / Login 😉
@axisofevil: I think that was super-sensible to make sure the MBR, Boot Sector etc was put in the right place
Jim,
Re: alternative OS
12-05-2008 2:12 AM
Quote from: Prod_Man @axisofevil: I think that was super-sensible to make sure the MBR, Boot Sector etc was put in the right place
Well since the PC in question is a Triple-boot Windows 98/Windows NT/Linux setup I'm faced with two choices:-
a) Carry on running the bits of Windows (just so I can switch to the Linux bootloader)
b) Re-Install Linux after switching the external drive back into the case (the PC has a primitive BIOS).
I will probably have to replace it soon - latest Linux upgrade is a bit slow (only 384MB main memory) - it doesn't do too badly for an 8 year old PC!
Re: alternative OS
12-05-2008 10:59 AM
Re: alternative OS
12-05-2008 9:50 PM
Quote from: Kelly None of the processes you guys are describing is particularly easy for a new to linux user though.
Yes this post was bound to get opinions flowing.. like others I thought "hey I know something here"! Choices are something that ironically puts people off Linux...
Perhaps the Original Poster might say what he (or she) would like to do? Just try Linux? Build a serious stand-alone installation? Put some old equipment to use?
If we haven't scared him/her off ...
Re: alternative OS
13-05-2008 11:02 AM
For some time I have been wondering if I should have a go with Linux but it has to be simple. I therefore checked on the Dell site which retails a basic laptop with Ubuntu for just short of £300 but I would really like to spend a bit less than that in case I don't like it.
I only use my computer for basic things so don't want anything over the top.
The questions that I have are:
Anti-virus, spyware and firewall requirements
Updates
Does it require cleaning up temp files etc like Windows?
Will my Epson DX3850 all-in-one work?
How easy is it to set up wirelessly (I use a Linksys router)?
Would I need to use Open Office?
I know that I could trawl the forums for information but I am certain that you experts can handle this in seconds.
