alt.binaries???
suesykes
alt.binaries???
Why cant I get amy alt.binaries on my newsgroup reader... Im using outlook express, no problem with anything else just the binaries.
Are they blocked by PN?
5 REPLIES 5
Peter_Vaughan
Re: alt.binaries???
Plusnets newgroup feed is text only and has been for many years.
For binary access you will need to subscribe to a outside newsfeed supplier.
pcoventry76
Re: alt.binaries???
as Peter says.
You say all binaries, do you mean you cannot get ANY or just that specific group?
Peter_Vaughan
Re: alt.binaries???
They don't exist in the newsgroup list and thus are not selectable.
VileReynard
Fixes: 20
Re: alt.binaries???
Have a look at http://www.newsservers.net/index.php. I have no idea how uptodate it is.
jelv
Fixes: 10
Re: alt.binaries???
I wouldn't rate that site - it still lists beta.usenet.plus.net (212.159.2.86) and under software it only lists two, one of which is Outlook Express!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
