advice please on Linux Mint 13
gleneagles
Aspiring Legend
Fixes: 17
On attempting to boot up I get the following message with Mint 13.
The disk drive for/media/bigdrive is not ready yet or not present.
Continue to wait or press S to skip mounting or M for manual recovery.
Pressing S get's me to,
File system check or mount failed
A Maintenance shell will now be started.
Control D will terminate this shell and continue booting any further errors will be ignored.
From that point I can get to the desktop but I don't want to go through this every time.
I Do have a copy of Rescatux will this solve the problem or should I be checking something out first ?
Any ideas why this might have happened or is it just one of those things ?
We are born into history and history is born into us.
11 REPLIES 11
ejs
Aspiring Hero
Fixes: 25
Re: advice please on Linux Mint 13
/media/ is (or was) where auto-mounted drives go.
Edit /etc/fstab and change or remove the line for /media/bigdrive - you shouldn't manually mount things in the same place where the auto-mounter will put things.
gleneagles
Aspiring Legend
Fixes: 17
Problem is I am now getting this message,
gedit /etc/fstab
(gedit:2354): EggSMClient-WARNING **: Failed to connect to the session manager: None of the authentication protocols specified are supported
** (gedit:2354): WARNING **: Could not connect to session bus
ejs
Aspiring Hero
Fixes: 25
I recommend leafpad (GUI) and nano (terminal) for simple easy to use text editors.
Waldo
For editing system configuration files, which require root privileges, I find it simpler to use nano.
$ sudo nano /etc/fstab. Edit as required. CTRL+O to save and CTRL+X to exit nano.
I guess if you want to use gedit you should be using either
$  gksu gedit /etc/fstab
# dbus-launch gedit /etc/fstab
gleneagles
Aspiring Legend
Fixes: 17
Changed the line with the text editor but now get the message,
An error occured whilst mounting /etc/fstab.
Would I be better just deleting Mint 13 and then reinstalling it again ?
HairyMcbiker
All Star
Fixes: 21
Post your fstab here.
Or if you haven't customized it far it maybe quicker to delete and start again.
gleneagles
Aspiring Legend
Fixes: 17
This is going from bad to worse, when I now try to get access to etc/fstab I now get the message,
sudo: must be setuid root
There is plenty of info on the net about setuid root but I think It will be quicker and easier to wipe my drive and start from scratch but it would be helpful to know what might have caused this problem in the first place.
ejs, mentions that you shouldn't mount things in the same place where auto mounter puts things but I didn't mount anything and the problem was flagged up when booting the system.
ejs
Aspiring Hero
Fixes: 25
Probably a bit late now, but what was "bigdrive" supposed to be? An internal disk or partition? Or an external drive?
HairyMcbiker
All Star
Fixes: 21
Quote from: gleneagles
That is weird, you should be added to sudoers when you created the FIRST account.
Wipe it and try again, maybe a bad install.
gleneagles
Aspiring Legend
Fixes: 17
Wiped the drive and reinstalled everything.
I have 2 partitions on the drive, one with Windows 7 & the other with Mint 13.
Must admit there was a lot of rubbish that had collected on the Windows drive so I was not to adverse in going ahead with a complete reinstall.
Everything is spot on now so thanks for all the responses.
HairyMcbiker
All Star
Fixes: 21
I only meant reinstall the linux part, but M$ does benefit from re-installing every 6 months anyway to remove all the crud.
