advice on windows 8
zedingrove
advice on windows 8
Downloaded win 8 the other day and warns can't uninstall to previous version.
So being a pre-release does it have limitations or could one get away with it?
Fixes: 24
Re: advice on windows 8
It's time-limited i.e it will expire (as I understand, on 16th January 2013).
zedingrove
Oh cool thanks for that!
Got to say have just done a clean install and the installation was amazingly quick... Windows elements some are really cool, others bit naff but system resources am running chrome and yet is using average of 0.5% of the cpu...
St3
Aspiring Champion
Fixes: 5
i read that win 8 will cause issues for pc gamers, let me find the link http://www.bbc.co.uk/news/technology-18996377
