activearmor firewall
- activearmor firewall
19-07-2008 1:39 PM
Does anyone know a simple way how to delete this off my computer, its not in the add/remove programs. I Have it switched off but keep getting a nag screen telling me it is switched off.
We are born into history and history is born into us.
2 REPLIES 2
Re: activearmor firewall
19-07-2008 4:30 PM
Have you tried:-
Clicking on 'Start (bottom left of screen)
Click on 'Search
Click on 'For files and folders'
Click on 'All files and folders'
In the 'All or part of the file name' box put the porgramme you wish to remove and click search. You should then be presented with details of where the programme is installed. You can then highlight and delete. It will then be moved to the recycle bin which will give you time to check that your pc still works ok. If you have problems you can reverse your actions by reinstalling all deleted files from the recycle bin.
Hope that's of some help,
Have you tried:-
Click on 'Search
19-07-2008 11:17 PM
I did a quick google search using the words "remove activearmor firewall" and found that it was installed with NVIDIA software. It doesn't seem easy to remove but go to this page and see if it helps.
