accessing e-mail account
- Re: accessing e-mail account
16-02-2008 5:19 PM
Hi
I am having trouble accessing one of my plusnet e-mail accounts. Error message comes up for incorrect password, which hadn't been changed.
However in case this had got corrupted I changed password, but still can't access.
Any suggestions?
gom
Any suggestions?
gom
4 REPLIES 4
16-02-2008 11:34 PM
PJ
You will have to excuse my stupidity but what is the difference in checking accessing by webmail or e-mail.
Yes I have checked in login details and they appear to be correct.
gom
gom
16-02-2008 11:39 PM
Webmail is a web based email program whereas Email usually refers to your own email client.
Using webmail will eliminate any possible config errors in your own Email program by checking the login & password are working via a web login.
You access webmail via http://webmail.plus.net
17-02-2008 8:14 PM
I can access my other e-mail accounts by using the webmail link on plusnet web site, so presume the account I cannot access will also be webmail.
Have just tried again but with no success, will have to ring in to plusnet and resolve.
gom
gom
21-02-2008 8:45 PM
Problem solved, hadn't used the account for 90 days, it's gets suspended after this time of inactivity.
gom
gom
