Zone Alarm
- Zone Alarm
Zone Alarm
03-05-2008 7:09 AM
Many years ago I used Zone Alarm firewall, but with a number of PC changes it just got side-lined in favour (because it was already there, rather than any other tech reason) of Windows Defender. But following advice in these forums, I decided it may be a good idea to reinstate ZA. I duly downloaded what I thought was the free ZA firewall, but found after installation it seemed to be an entire AV suite, which seemed to require me to disable the resident AVG 8 and MS Defender etc. ( I have uninstalled the ZA)
That is not what I was looking for, I was hoping just to be able to use ZA firewall as an added protection, not the main AV programme (I'm otherwise quite happy with AVG)
So, have I found the wrong programme? if so which (if available) is the stand-alone (free) ZA firewall?
5 REPLIES 5
Re: Zone Alarm
03-05-2008 7:31 AM
visit zonelabs.com for zone alarm.
Re: Zone Alarm
03-05-2008 7:50 AM
The link to the free version of ZoneAlam is http://www.zonealarm.com/store/content/catalog/products/sku_list_za.jsp%3Bjsessionid=1JJxrNiUZdWMMiM...
Bob
Bob
Re: Zone Alarm
03-05-2008 7:53 AM
Ah. thank you bobboulby (and artificer) that's what I was looking for.
Re: Zone Alarm
03-05-2008 8:20 AM
Also the free version gives you the option at install time to try the full pro product for 30 days. This may have been what confused you if you said yes.
Re: Zone Alarm
03-05-2008 3:34 PM
Yes, quite right Peter it was.
