Zip goes a folder? Or not?
- Zip goes a folder? Or not?
03-03-2018 12:30 AM
I have several graphs in jpeg format. If I place them in a folder and zip it, will I be permitted to upload it as an attachment to my post?
Re: Zip goes a folder? Or not?
03-03-2018 12:37 AM
Zip isn't an allowed format, perhaps you could rename the zip file to one of the allowed types and upload that?
03-03-2018 11:10 AM
So how big are these files? If they're only graphs they shouldn't need to be very high definition. If they are too big then why not reduce their size? Options for doing this include photo editing programes (I use photoshop elements), on line free services or downloaded free compression software. Another way would be to print them then rescan the print at lower resolution.
03-03-2018 11:32 AM
The number of files was the problem. I do have photo s/ware, but it would be tediously time consuming.
Worked around by bulk conversion to PDFs and binding them in 1 file.
03-03-2018 11:40 AM
@Luzern - It may be moot but FWIW most, if not all, graphics software should allow you to batch convert / resize without being overly tedious.
03-03-2018 2:58 PM - edited 03-03-2018 4:35 PM
Super fast File resizing prog....
Fastimageresizer https://adionsoft.net/fastimageresize/ its free ! !
and you can get the resized images in your existing folder location in a NEW folder called "Resized"... so all your copies are in the same location.
simple to use... just drag and drop as many as you like on to the icon on the desktop, and within seconds they are all done and dusted...
