Zenpad wifi
- Re: Zenpad wifi
Zenpad wifi
25-08-2015 10:34 AM
I recently bought a Zenpad Z170c for my son , nice little basic tablet But for some reason the WIFI signal is terrible , only say Poor reception even when next to my router a DSL ac68u , i have it set on 2.4 , but no better on the 5 ghz
i also have tried the channels on auto or individual 1 to 12 but cannot get a decent reception
anyone had one of these , or any ideas .
Ps wifi is excellent on Laptop , and phone
8 REPLIES 8
Re: Zenpad wifi
25-08-2015 4:47 PM
not sure if this will help..... scroll down a bit and see what some are saying ...
http://www.androidtablets.net/threads/zepad-wifi-connection-problem.27884/
Re: Zenpad wifi
25-08-2015 5:13 PM
Cheers Shutter some good info there , will give it a try
Re: Zenpad wifi
26-08-2015 12:35 PM
Had no luck improving wifi , so contacted ASUS support yesterday , i Got a reply back Just now Quick service
they say try a factory reset wipe everything and if still no better have a word with the store i bought it from , refund or replace looks like a visit to Currys soon
Re: Zenpad wifi
27-08-2015 10:20 AM
Me like Currys
took the pad back this morning , had a Good moan and complaint with manager , Got a Free replacement Upgrade worth £40 to next model
Re: Zenpad wifi
27-08-2015 10:23 AM
Well done
Re: Zenpad wifi
27-08-2015 1:19 PM
Ah.... but....... does it work on your wifi ?
Re: Zenpad wifi
27-08-2015 9:01 PM
Yes shutter 100% signal anywhere in house , am well chuffed
i had the zenpad 7 , now i have the zenpad 8
Re: Zenpad wifi
27-08-2015 9:21 PM
That.... is a result ! !....and better than windows 10, too ! .... windows 10 was a FREE upgrade... but you did not get a new/better machine with it ! ! ...
