ZTE F102 Phone
- Re: ZTE F102 Phone
ZTE F102 Phone
27-07-2012 6:52 PM
There is supposed to be some way of recording videos on this phone as mpeg4 (?) which might transfer because I can watch mpeg4 video on my pc, but I cannort find how to persuade this phone to record in that format.
To add to that, I received a message yesterday which included a video which I want to get to my pc. I have (unfortunately?) moved this video into a user folder. From here I can only forward it (to another phone?), delete it, or reply to it
Any thoughts of how to solve these two problems?
Re: ZTE F102 Phone
30-07-2012 10:39 AM
its found here
http://www.videolan.org/vlc/index.html
Re: ZTE F102 Phone
30-07-2012 8:12 PM
Y HTC phone saves 1080p videos as 3pg and I simply drag them to a folder on the PC and VLC Player plays them without any problems.
Forum Moderator and Customer
Re: ZTE F102 Phone
30-07-2012 8:20 PM
Re: ZTE F102 Phone
31-07-2012 9:46 PM
At the moment my phone saves the videos as mp4, and my pc will play mp4. I have plenty of mp4 files om my pc to confirm this. I have also tried saving videos on my phone as 3pg files, but I have the same problem whichever format the video is in. The problem seems to be getting the file from my phone to my pc. The download software that comes on a CD with my phone, and which I have installed on my pc, rejects the video file when I try to copy it across to my pc. The same software quite happily transfers photos, it just doesn't like video.
Strange!
Re: ZTE F102 Phone
31-07-2012 9:57 PM
You will still need the drivers installed from the manufacturer but it is a simple program to use.
Re: ZTE F102 Phone
31-07-2012 10:05 PM
All you need to do is when you plug your phone into your pc via usb, cancel anything which attempts to load, ie S/W which came with phone, once done goto my computer? you will see pc has loaded a flash drive which is exactly what it is, open and depending how setup look for DCIM or downloads or media files from there you can copy and paste.
Re: ZTE F102 Phone
01-08-2012 7:40 PM
Thanks for all the help
Re: ZTE F102 Phone
01-08-2012 8:27 PM
I rebooted my pc and it started coming up with a message on the Desktop - the message supposedly coming from Nero and saying that the program requires file "advcrntr2.dll" which wasn't found. It repeated that 3 times then came p with a new message, this time from InCDgui stating "error in your installation. Your installation is corrupt - please reinstall this product"
I tried to uninstall Nero but it wouldn't go, and every time I rebooted my pc, my pc got slower and slower. I couldn't access Windows Explorer, Internet Explorer or anything that was started from icons on the desktop.
In the end I rebooted into Safe Mode and did a System Restore from two days ago. My pc now seems to be okay - as quick as it was before today, no error messages, the icons work, and according to Control Panel that Intell IQ Installer has gone.
Hopefuly, my pc is okay now
Re: ZTE F102 Phone
01-08-2012 8:59 PM
Re: ZTE F102 Phone
05-08-2012 10:53 AM
Thanks for everyones help
