Youtube
Youtube
No longer works on my "company owned laptop", I get a message.
Get the latest Flash Player
Learn more about upgrading to an HTML5 browser
Not much chance of upgrading the software or changing the browser as it is locked down.
Any suggestions
Fixes: 69
Re: Youtube
What browser are you using? Most recent browser builds *do* support HTML5. Perhaps you could run a portable version of eg. Firefox from a USB stick?
Plusnet Products Team
Re: Youtube
IE 8 + XP. USB ports are disabled.
Just found out BBC Iplayer has stopped working also.
Fixes: 4
Re: Youtube
What browser versions are you running?  If they are old, it may be worth pointing out that they need upgrading because of security problems and get them to fix the issue for you Cheesy
Re: Youtube
IE-8
Version 8.0.601.18702
Product ID 01398-997-0069222-39057
"Them" is the US government Crazy ..............long way to go to get youtube fixed
